Resume music after call - irritation
Ok, this is hardly a major problem. I doubt it is going to take the country to war or collapse the economy. It certainly doesn't even measure up against Bubonic Plague or Antrax but......
When playing music from my phone over bluetooth in the car, if I receive an incoming phone call, the music resumes playing after the call ends. However, if I make an outgoing call it doesn't and I have to manually select the media player screen and press the play button.
When not connected to the car, the phone resumes the music after a call.
There's probably a setting somewhere but I can't find it and it's bugging me....any ideas?
- LancsLad
What phone? and did you call out "through the car" rather than on the handset?
it could be the way the Phone interprets the call?
Try calling out from your phone itself whilst connected.
it sounds like the muisc app is stopping play as opposed to pause and auto resuming. I'm sure 'ive seen a setting somewhere on androids.
hope makes sense..but I'll test mine later.
The phone is a Samsung Galaxy S8.
I've just tried initiating the call from the phone instead of from the car and indeed, the music resumes when the call is initiated from the handset but not when initiated from the car.
For now, I've programmed the option key on the steering wheel to play/pause the music so at least I can still end the call and start the music with just one extra press of the steering wheel buttons.
