  • Gary
    Flat Battery
    Does anybody have problems with battery going flat after being parked for 10 days on airport car park really annoying as had to call out assistance
  • andynoiseboy
    Do you have dash cameras?
    Most probably the tracker...
  • Gary
    Flat Battery
    Yes I have Think Aware F770 dash cam front and back but was told it goes to sleep when engine turned off
  • Gary
    Flat; Battery
    hi never thought of tracker bur also car has in control pro fit could that be it as well
    I'm even more convinced now to keep a jump starter battery in the car, something like this.
  • DG
    Re: Flat; Battery
    Shouldn't be that as the motor goes into a very deep sleep 'low power' mode after 96 hours....I've been away for more than 10 days and it was fine Thumbs Up
    If the car is garaged and the tracker cannot get a satellite to lock onto, it drains the battery, as constantly scanning. This has happened to my Subaru several times if am away for 2 weeks, when cars garaged it struggles to turn over. I was away for 3 weeks once, and car was totally dead. The recovery guy told me this. It was the last thing I expected as I thought the tracker was only consuming minimal power. Obviously not! So now if am away, the Mrs alternates the cars after a few days to stop it happening again. Mind you the D5 has not been stuck in the garage for 2 weeks yet, so will be interesting when we are away for our 2 week break in October. I have purchased a solar panel with crocodile clips which connects to the battery, trickle charging it and seems to do the trick for my car.
    With regards to the dash cams I think the majority will turn off, once the cars switched off. That is unless you have it recording whilst car is switched off and fitted the module that shuts it off if the voltage drops below 12v or say after 3 hours, whatever comes first. I went down this route to prevent the battery going flat and its working fine.
  • DG
    It doesn't work like that ...it won't activate gps until unauthorised movement of over 200m is detected Smile
    Well it seems that different trackers operate differently but all need to lock onto a 📡.
    I know in my car that is the issue as like the guy said if it doesn't lock onto a satellite, it wont go into sleep mode, and it will continue scanning the airways until it locks on, or the battery gives up. I have a factory fitted RAC Trackster + in mine.
    Not sure about the brand of tracker the D5 has or how it works, as never had a tracker on the D4.
    Interesting info tho, thanks Thumbs Up
  • DG
    To clarify, I'm talking about LR Secure, not a 3rd party tracking unit ...but I cant see how they would instruct the GPS to be active permanently.
    Well all the cars journeys are logged when looking into the LR control app so I assumed the tracker is always on, so too speak?
    I think there is 2 tracker types in the D5 from memory. A basic one and a more advanced one which is subscription based which we ordered.
    Even when car was in the LR garage, the tracker activated, and I got the text saying cars possibly being stolen, as I forgot to put the car in service mode I think it's called which temporarily disables it. Has to be set daily as it reverts back on automatically after 9 hours I think.
    Car was in the workshop as I checked on the LR remote app.
    Not sure if it has the anti jacking feature though as if the wheels are off the ground it activates if the car is up on a ramp etc?
  • DG
    'Secure' is the only official LR tracking service I know of ....tracking with that is only 'on' when the motor is active and\ or moving.
    ...and yes you need to put it into 'service mode' if the battery is due to be disconnected or 'transport mode' if for example you are on a ferry ..that disables the motion sensor.
    Thanks for the clarification Thumbs Up
    My battery runs flat very quick as well when in the garage, but got a tracker from the insurance company, no idea which make
