  • vkord
    rear seats creaks and rattling
    Finally eliminated faint but annoying, persistent rattling sound from left rear seat area that was present in the car from the start. It was always happening during street driving. It was small plastic cover plate at the back, as seen in the picture. That plastic part was pretty loose, Just added some padding right under.
    The other annoying sound was due to side plastic cover panel of the rear seat rubbing over the leather when pressing on the seat. That was obvious and easy to eliminate by applying some conditioner over the contact area.
  • Seaby
    I'm going to check that as have to say any rattles I get are from the middle seats. Especially the seatbelts
  • Chalkys HSE
    Mine makes the most god awful noises if the middle row seats arent set back with the switch for the reclined position, it doesnt do it in this position but if they are in the more upright position it drives me crazy...
    Seperate to this i just found the rear right boot panel loose, with two black clips in the side down i the cavity, i think i've worked out how they went on but not sure if i should attempt to put them on or just leave it for the dealer to rectify, baring in mind i've got other more pressing issues should i just leave it ?
