      - SHARKYSHARKS
      3.0 engine whine
      Has anyone got the 3.0 diesel close to Manchester as I want to compare the engine noise
My D5 has been in the dealers for the last 6 weeks  cos of a whine on the engine !
I picked the car up on Friday and the dealer said that LR technical have told them the noise is generic to the model, I have told them that’s sh%+e as it wasn’t there when I picked the car up in Jan and I’ve never heard any more with the same noise !
So just to make  sure I’m not going completely round the bend I would like to compare it to another of similar spec.
Any help greatfully appreciated !
Sharky
      Do they not have a demonstrator or a used one there?
Keep the wine to drink, but definitely eliminate any whine!!
      - SHARKYSHARKS
      Jimbg
I didn’t even bother to ask after 6 weeks of driving a Jaaaaaaaag XE and then an Epuke I though I’d give it a go.
But the noise is still there and at the mo  ant be arsed taking it back again !
After 7 months of owning the car it’s been in the stealers for 2 months And ive only done 4.5 K in it !
Ps noted on the Whine .........Wine
      - arsi
      I am not close to you but I noticed last week a high pitched noise that is correlated to engine revs.
My D3 did have similar noise when alternator was on final laps.
My D5 is a year old now and had its first yearly service three weeks ago.
      - SHARKYSHARKS
      Hi Arsi
That’s the same as mine but the stealer changed the alternator, ac pump, idler pulley while doing their investigations 🤔
      - arsi
      Just listened carefully the whine on my D5:
- Can not hear it when engine is cold. It starts only after a few kilometers drive.
- Pitch raises according to the engine revs.
- Whine continues for a second or two after engine stops with lowering pitch.
-> Turbo? Or is there something other that continues to run after engine stops. FBH should engage as ambient temperature is so high.
I am confident that I had not that pitch earlier. Could oil change initiate it?
      - SHARKYSHARKS
      Mine  does it all the time whether hot or cold !
      - Qwertyd5x
      At 9k miles, mine has suddenly started making a whining/buzzy noise.  It is slowly getting worse.  Mostly and very noticeable on acceleration, particularly from lower speed/revs.  Possibly louder when engine warm.  But nothing if just reving the engine when stationary and it stops when travelling at a constant speed/revs.  Nothing if you coast the vehicle and nothing? if you go down the gears manually even though the revs spike, but road speed held constant.  Nothing visible to see.  I don’t live near a LR dealer.
Any suggestions?
      - mse
      The is a universal fix for engine noise, been around for years...
Turn the stereo up and stop listening for it
      - IndusD4
Any suggestions?
Maybe the turbo is getting noisy?
