  • olav
    Norway
    Miles reading
    My D5 3.0 HSE speedometer reads ca 4 km/h too high. This means that when the car has done 96000 km the ododometer reads 100000 km and garantie is out. Can this be adjusted. I have original wheels and tyres
    Do you mean 4% error or 4km/hr at a particular speed.
    There is a difference!!
    Not an expert, but is the odometer linked to the speedometer calibration?
  • olav
    Norway
    Odometer reads 4 km/h too high. Checkt t with gps. When speedometer on 86 exact speed on gps 80 km/h
    Take into account that a GPS system will calculate speed as time taken to travel between 2 points in a straight line. It does not account for curves or any increase of decrease in altitude. You also need to accept that the device has a limited accuracy based on the (limited) number of satellites it is picking up, its refresh rate and the speed you are actually doing. All of these are averaged out to give a steady speed but it will lag behind.
    GPS is a position finding system, speed calculation is a secondary function.
    The speed reading is set high by design (it is illegal to sell a car where the reading is too low, so they put in a safety margin). On the D4 this could be adjusted using a IID tool but was reported to cause more problems with other settings if you did.
    Despite the speed reading being high, the distance travelled will still be very accurate unless you change tyre diameter away from standard.
    86 - 80 = 6 ?
  • graemesmith1960
    In the UK every car I've had since the availability of GPS has read 2mph high. On a trip to the USA many years ago I was surprised that the rental speedo actually read the correct mph!
    I haven't heard of a car sold in Europe that didn't read high. On recent cars its been a constant 2mph across the speed band, not a percentage. As has been previously mentioned the IID tool can set the overread value on the D4.
    2019 Sd6 HSE Corris Grey
