- vkord
TPMS
Does anyone using or know not too expensive <$200 TPMS reset tool that works with LR original sensors? They are misslocated on my winter set, and if you moving wheels from front to back reset is necessary anyway,
- Pcheaven
They should auto configure and identify which wheel they are on after a short drive. If they don’t, might be an idea to get a dealer to check why
- vkord
It was reading correct pressure after I have installed winter set but sensors location was incorrect, left side was showing 37 on front and rear, but in fact only rears had 37 psi, then on the third day got message TPMS system failed. Sensors are original LR , new. Will try to schedule the appointment but it’s a month wait time here.
- ken
Cheap ones are worthless
We use Wurth & Snap-On with the EZ-Sensor clone valves
LR are self learning with Original Replacements
Also just fitted Winters to the Red D5 with wheels from a 2016 L405 no issues at all
I think new sensors ship in a battery saving "sleep" mode and that they need to be woken-up "activated" before use with an appropriate tool (125MHz signal) from what I've been able to discover. Then they should be auto learn after that.
- vkord
After about one week of driving the message "Tire Pressure Monitoring Sytem Fault" went away , just as I was dropping the car at the dealership to look into it.
They told me that it takes 100Km of driving for TPMS to learn the new sensors. I have original LR sensors on the winter set.
I guess it is too much to expect more meaningful message when the system goes through learning cycle.
BTW HAKKAPELIITTA R3 SUV are very nice indeed.
- Coffeecup
I've switched my 21" wheels for 19" wheels that came off another Disco 5 about 300 miles ago, and I've got the "Tyre Pressure Monitoring System Fault" message coming up.
As a "quick" solution I'm looking into having a local tyre garage taking the tyres off my 21" rims and the 19" rims and swapping the TPMS sensors over, and putting the tyres back on and putting the 19" back onto the car !
I'm looking to sell on the 21" rims so won't bother putting the tyres back on these.
Laurence
- Pcheaven
Strange you are having issues
On my 17 plate hse lux I had no issues when I swapped wheels
Tpms worked almost immediately.
- Coffeecup
