  • TechnoTurkey
    Mirror Power Fold - Turn off?
    Is there a way to stop the mirrors folding when you lock the car?
    If I fit my towing Mirrors then the brackets will catch on the bodywork when the mirrors fold which is far from ideal and I can't be relied upon to remember to remove them when I lock the car!
    My previous car had an option to disable the fold which would be highly useful (E-class Merc).
  • Chopsy
    My understanding is that this is possible, but something the dealer has to do. If I am wrong, I'm sure someone else will correct me.
  • TechnoTurkey
    That sounds like a pain, I'll see if I can find a way to fit them so that they don't catch.
  • Chopsy
    If it helps, I think you can manually fold them in by pressing both left and right mirror selector buttons at the same time. Then they stay in until you press both again - even if you lock and unlock car.
    This may help position the mirror extensions whilst they are folded in. Just a thought.
  • B50int
    I had that problem too. Now I clamp the tow mirrors to the top of the mieor body but inverted. Now the powerfold works fine with the mirrors in situ and fold the tow mirrors in too without the clamps colliding with the bodywork.
    Jon
  • TechnoTurkey
    That's exactly what I ended up doing Thumbs Up
    Hi guys what mirrors are you using to fit
    I’ve got my old milenco from the D3 but need advice
    I'm sure you can turn the auto powerfold off in the centre dash menu options...I'd have to check to be certain though.
    __
    Had the old Milenco Aeros but now have their Grand Aero…fastened on the top of the mirror…which I find the best and most stable/vibration free versions.
    Any photos ?
    I’ve got milenco’s but not sure witch ones
    I’ve had to use short bungee’s to strap round the mirrors looks a right mess
    This is the newer model Milenco Aero just fitted roughly to get you a picture. Note the arched foot which gives a better grip. I had the older type with the flat feet and one fell of last year hence the new ones 😂.
    Nice thanks PRH,
    I just need the arch pieces to make mine fit better. Can they be purchased separate?
    Sorry no idea, mine came like that.
    I think I’ve got the same but the clamps I’ve got are crap with the mirror body curve
    I need some curved feet like the previous post
