- PaulC555
Sat Nav Help
Evening all
Can anyone point me in the right direction with this?
Can’t seem to find where or if it’s possible to alter route settings on the sat nav. Usually you can change between shortest (most direct using all types of roads) or quickest which tends to stick to main roads?
Would like mine to stick to main roads where possible, but at the minute it’s taking all type of shortcuts through housing estates etc.....
Is this possible?
Paul
MY18 HSE Corris Grey with Black Pack
- DG
When you are in the nav system main screen you should see the setting icon at the bottom ..it looks like two cogs ...when in settings you should see
Quote:
Navigation:
Route options: Select to avoid certain road features.
