- Gary
low Battery warning
Has anybody had problems with low battery if car is not used for a week then low battery lights comes on and if left any longer have to use power pack to start engine really not good and starting to lose confidence with Land Rover
- Chopsy
I have read similar posts.
My experience though, having had 2 D5's so far, is that I haven't found this an issue so far. I use my D5 only occasionally, when I am doing slightly longer journeys. In 4 months I have only done 1000 miles. Regularly sits 7-10 days between use.
I have seen it suggested that leaving it unlocked (if in a garage) does not put all the systems to sleep??
- Russell
I have left the car sat for two weeks with no issues. However I do unplug the dash cams as both running 24/7 does take it out of the battery otherwise
- SHARKYSHARKS
Re: low Battery warning
Iād get the battery checked Gary not uncommon for the battery to go tits up after a few months š
- Chopsy
The optional tracker system can have an impact if fitted.
- harrythespider
Mine regularly is left between weekends with dash cam on, No problem.
