- al cope
battery cover
Chaps
what is it the actually holds the battery cover at the right hand side of the load area in place. Mine seems very loose and sits forward of the hard plastic trim. I can see the 2 locating pins on the back of the trim and the 2 holes these go into but the seems nothing to "lock" the trim in place.
- al cope
There doesn’t appear to be any sort of slider in mine 😟
you've bust it?
- Dangerdave
They can detach.
Have a look at the panel and also on the bodywork just to see it’s not stuck on one or the other. It’s a long bit of black plastic with a long notch at one end and another halfway down.
I put a plastic tie round mine with a little bit poking out so I can just tug at that and the slider will come off no problem
- al cope
Looks like I am definitely missing that bit of plastic. Wonder if I can buy that on its own or find a breaker with a D5.
- Dangerdave
- al cope
yep - mine is definately missing that bit
- Dangerdave
To be honest, it’s a stupidly designed bit. It comes away from the side really easy. Have you looked in the bottom of that battery recess or adjacent bodywork. It didn’t get stuck on the trim that you removed?
- al cope
no its definatelt not there - dealer is ordering one for me FoC.
- Dangerdave
Result.
- al cope
turns out its only 16quid, and they will fit it while I wait - taking it in next wednesday
- al cope
well it turns out its not the 16quid part, but big shout out for my dealer as my car was in this morning for this bit to be fitted, and when they found it wasnt the part they'd ordered, they took the bit I needed off a brand new D5 and fitted it to mine whilst I waited. No complaints from me
- Dangerdave
That’s how it should be, but a rarity these days.
- mordred1973
haha they'll then probably forget to replace it on the new one and deliver it without (like my luggage cover)
