  • Yorkietiger
    Adblue top up
    As I am embarking on a long trip with the caravan next week across Europe I thought I would check the DEF level this morning. It said 4163 miles to fill up, so as I will be working the car quite hard with the caravan I topped it up, put about 2 litres in, as I did not know how much 4163 miles worth would be left in the tank.
    After topping up, I took the car out and then checked the level again. It still said 4163 miles! Does this value need manually resetting or is supposed to reset itself?
    It should reset itself.....but if a top up was required, it should also say "Max refill = xx Litres"
    It takes quite a lot, I usually buy a 10 litre container from Halfords and it all goes in! Thumbs Up
    I wouldn’t top it up unless it says you can put so many litres in. Not sure working the car hard makes a difference to consumption.
  • harrythespider
    Be very careful when topping up, If you overfill, it can cause an error on the system and require draining and possibly a trip to dealer to reset.
  • Trevorb1
    Yorkietiger, if you car is a 17my, you dont get a warning until down 1500 miles till no restarts, at 18my the service menu was updated to give a count down and an indication of number of litres to fill when its 5 or more litres. I wait till it says 10 litres to refill then buy a 10 litre container from halfords and pour the lot in, the tank should have a total volume of about 18 litres from memory. When towing my Tdv6 uses adblu at about twice rate as driving solo. 17my need the dealer to tell how much is required to fill I'm afraid.
    Really? It is no different to topping up your washer fluid.
  • DiscoStu
    Agreed, just brim it. You can’t overfill.
    It won’t change amount until it cycles, so a short drive won’t change the tank level.
    MY19 Silver HSE Lux SDV6
    When at the dealer I let them fill it up, regardless the remaining km, never had issues, and it does reset itself indeed, but it’s always a lot of liters, like 10 or more.
  • Trevorb1
    Discostu, afraid your wrong, you can overfill it, the float in tank can go too high and it looses its reading and will shut car down, only way to recover that is get car to dealer who has to drain the system so that float can regain its reference.
    ^^^^ I was also told that by my dealer's service manager. I haven't tested it. Thumbs Up
    Really! I too was under the impression you could overfill it.
    If you have it on the dash screen that it will take 5lts, then it takes any guess work out of topping it up, but hey, each to their own, OP wanted advice, I just replied, disregard it, not bothered, but I didn’t want to get into an argument about it.
    I do not not have any indication in my MY17 so I just fill up when I think it getting low, in the same way you you do with washer fluid.
    If you have an indication in your car the it makes sense to take a different approach.
    Strange that your 2017 doesn't have this, the indication comes up in the centre display but only when there's just enough for 2,500km. You need to click on "ok" to make the message go away. The message is white when it first appears, at 1,500 it changes to orange and changes to red when it gets really low.
  • Blackfly
    my 2017 received an update at the 1 year service that shows distance to service and DEF refill. This is seen in driver assistance vehicle information (I think). you can only see the information with the ignition on and the engine NOT running.
    I will try and find my service invoice which should list the update
