  • Sacimiddx
    Driving in France and Spain
    Any idea what we do about sparebulbs and headlight beam deflectors ?
    any other points and advice gratefully received !
  • MURPHY108
    Hi we're currently down near tolouse, so first hand experience (mine is aMY19)
    The manual says the headlights have a beam pattern that means you don't need to adjust or add deflectors.
    There is an adjustment for auto high beam assist in the menu..
    Believe my bulbs are LEDS so not replaceable, however I also have a spare bulb kit in my toolbox from my D4.
    If you have the digital dash you can change to km/h.
    If you have the speed limiter it's invaluable as they have changed speed limits in rural areas.
    The adaptive cruise control seems far nore sensitive to cars exiting the autoroute so assume the forward looking cameras are calibrated for driving on the left.
    There are speed cameras everywhere, much more than I have seen in previous years, I had the cruise set at 130 on the autoroute in good weather when I was overtaken by a Picasso who cant have been going much over 130 and he got flashed ,(blackvue showed I was doing 79mph so 127kph) so the tolerances seem very low. They have also introduced average speed cameras which seem mainly on downhill stretches.
    Several of the toll booths had the gendarmes out in force , we were told they are clocking you as you come up to the toll booths and the speed limit drops and we're pulling over cars when they came out of the tolls.
    If it's not too late get a toll tag, we've had one for years and they are invaluable.
    Hadn't realised the breathalysers had an expiry date , last minute trip to Halfords was needed.
    If you are getting the tunnel it was packed last Saturday , we ended up with a three hour delay and then they couldn't open the door when we got to Calais. Big Cry
    France has gone really expensive , £110 to fill up on the autoroute Shocked
    Some of the driving is unbelievabley bad , again much more so than previous years,
    Having said all that the D5 was a dream coming down , much more relaxed than the D4 and managed 38mpg down to the tunnel also hardly seen any D5,s
    Hope above helps , enjoy your hols Very Happy
  • Sacimiddx
    MURPHY108
    thanks Thumbs Up
    You should also have one of these https://www.certificat-air.gouv.fr/en/
    The breathalyser law was never enacted in France so not really necessary to have those.
    I presume you also have hi-viz jackets for every one in the car and a triangle?
  • Sacimiddx
    thanks jimbg
    2 triangles for Spain !
  • PaulP
    Spain
    Yes - 2 triangles are required by law in Spain.
    If you breakdown, one must be placed clearly visible just behind of the vehicle and the other one should be on the hard shoulder 40-50m ahead to warn oncoming traffic.
    Hi-viz jackets are required for all passengers and must be worn if you get out of a car on the motorway (or other roads) due to a breakdown.
    I'm pretty sure that there is a menu to configure the headlamps for LHD or RHD beam pattern but can't check right now but this should also adjust the auto-high beam detection.
