- Coffeecup
Dash and ignition dead
Was driving along the motorway when suddenly the in car entertainment system went off along with all the dash - speedo, Rev counter - everything.
The car continued to drive Ok so I’ve pulled in to a service station.
I now can’t restart the car, as all the ignition / dash is still blank / dead
I can lock the doors etc but can’t close the windows - even pressing and hold on the lock button on the key fob
Waiting for AA (Land Rover Asssit).
Has anyone else had this issue - is there a reboot fix to get out of the issue ?
Laurence
2005 TDV6 S - Tonga Green, 2008 TDV6 SE - Stornoway Grey, 2010 SDV6 XS - Galway Green
2017 D5 HSE LUX 3.0 SDV6 Grey 2019 D5 HSE 3.0 SD6 White
That happened once to me while I was driving, but the system rebooted itself about a minute later (while I was still driving) and hasn't done it again.
Try locking the car, waiting a minimum of 10 minutes for everything to shut down properly then see if it reboots.
You could also try disconnecting the battery to completely power down the car and see if that resets the system.
- Coffeecup
I’ve just received the vehicle heath check video from the garage - they’ve identified a water leak and that a module has been damaged due to water.
So they will be rectifying the water leak and replacing the water damaged module to resolve the no start issue.
Not actually spoken to anyone yet, so don’t know how long it will take to relive or whether it will be covered under warranty - which I do hope it will be.
Laurence
- Blackfly
my 2017 was subject to a update/recall at the last service N292 windscreen leak needs ti be checked. My service was at the end of May. this year.
N292 "may" be related to your problem
