- pouls1
Original tires good enough or AT's?
Wondering about how capable the stock tires (Pirelli Scorpion) are? How far can they be taken into any landscape before an AT is necessary?
- ukms
That’s a very broad question and completely depends what type of ‘landscape’ you are talking about. Surface, weather etc and how often will all be a factor and also whether you want to make the change permanent or swap wheels each time.
On the D5, the standard tyres will get you much further than you'd expect before you get stuck. AT tyres will get you even further but when you eventually get stuck, you will be further from rescue.
- beeker
I was surprised how far the scorpion took us on dry bumpy hill climbs, river crossings, icy mornings.
As long as you take it easy
Flip side, they were a bit average on the open road compared to my usual Michelin super sports on my rs6
- pouls1
- pouls1
An opportunity for many to give their 5 cents and create a good discussion then
- pouls1
Haha - I would hope so!
- pouls1
Mine has 22's and I am drooling a bit over pictures of 20" 255/55-20 and 275/55-20 KO2's and Duratrack's.
I love the look of the car on 22's, but with the lack of good AT choices in 22" and the low side wall height it would result in, I am considering the move to 20"
However, it comes at a price and hence the question about how far the stock tires would take me.
The worst terrain I will have to tackle are rocky roads and paths with the occasional big rock or rut where no normal cars could pass.
- Labbix
I have done this regularly here in Albania on the stock tyres, but 20 inch, no problem at all, yours being 22 inch you will damage the rims more easily.
In my experience AT are way better for mud, snow, sand and continuous gravel mostly because I feel more assured. But if you go slow and with caution your standard ones will bring you way further than you imagined
- Labbix
But be aware of your pressure!
>> The worst terrain I will have to tackle are rocky roads and paths with the occasional big rock or rut where no normal cars could pass. <<
I would inflate them at least half bar higher than normal for this specific terrain, and definitely with the 22 inch ones as they don’t have a lot of rubber between rim and terrain and go slowly! For sand deflate them, even a bar or so, for mud normal pressure, but maintain your momentum. I always have a full size spare tyre with and a compressor of course and a basic repair kid, with tow ropes and shackles (regardless if I am on stock or AT tyres).
- pouls1
Thank you Labbix! Appreciate your advice!
Any thoughts about 255 vs 275-20's Have come across one set of each.
- Labbix
- pouls1
I went for the 275/55-20 Ko2's
MY 2019 Fuji White SDV6 HSE Luxury with Dynamic 2, 360 cam, Head Up, 5011 gloss black 22", Pimento pinstriped black leather...
- Labbix
Can you let (me) know your findings, as I normally would go for the duratracs 255, as I had them on my D4, but real world info for combo D5 and KO2 275 gets my attention as well
- pouls1
Absolutely! I'll keep you in the loop
Got to get the car shipped from the UK to Cyprus first... I'll be spending the winter there and got this for exploring there. Car is being prepared as we speak and the wheels are delivered to the dealership so they can put them in the car - unless I get someone to take the 22's off my hand
Car will be in Cyprus on the 28th... can't wait to see it...
