- tej
thudding noise when turning left
Hello All
I own a MY18 3.0 TD6 Disco 5 Diesel (equipped with active rear locker) which has done 63000 kms. All good so far but since about 15-20 days when i steer left (whilst doing less than 40km/hr) I hear loud thudding noise from my rear left wheel. Its as if the rear locker is still engaged and the differential teeth or something is slipping. Does not happen when i turn right. Does not happen when on speeds greater than 40km/hr. Does not happen if I am not accelerating. Happens more often and is louder when on an incline.
Has any one faced this issue? I am going to the dealer day after tomorrow but wanted to check over here too?
Thanks in advance.
- IndusD4
I've not had this issue but you could check if the rear locker is engaged on the 4WD info screen.
- tej
Yes, the locker is engaged for a split second. I think it disengages little late than it should. Rather the rear locker should not engage on drive mode (comfort mode)
