  • tej
    India
    thudding noise when turning left
    Hello All
    I own a MY18 3.0 TD6 Disco 5 Diesel (equipped with active rear locker) which has done 63000 kms. All good so far but since about 15-20 days when i steer left (whilst doing less than 40km/hr) I hear loud thudding noise from my rear left wheel. Its as if the rear locker is still engaged and the differential teeth or something is slipping. Does not happen when i turn right. Does not happen when on speeds greater than 40km/hr. Does not happen if I am not accelerating. Happens more often and is louder when on an incline.
    Has any one faced this issue? I am going to the dealer day after tomorrow but wanted to check over here too?
    Thanks in advance.
    I've not had this issue but you could check if the rear locker is engaged on the 4WD info screen.
  • tej
    India
    Yes, the locker is engaged for a split second. I think it disengages little late than it should. Rather the rear locker should not engage on drive mode (comfort mode)
