- kevofcov
V6 and straight 6 engines
Quick question
I'm clear that the SDV6 is a V6 layout - I've assummed that the TD6 is a straight six.
I been told that its not and that it is just a V6 with one less turbo. Which is correct?
- Trevorb1
TD6 is same as SDV6 but single turbo instead of twin.
The TD6 and the SD6 are both the same V6 block that was used in the D4 as the SDV6.
The TD6 was fitted up to MY2018 and has a single turbo. The SD6 was fitted from MY2019 onwards and has a twin turbo (and extra air intake and air filter on the driver's side of the engine bay).
- lucero
They aren't the same as the D4 engines. They are new. Those were Ford units.
- Labbix
I believe they are still the old Ford engines... a straight six would be new and called Ingenium...
- mordred1973
Ford engines that were developed for the D3 in 2.7l capacity and fitted to Peugeot Citroen as well as Ford Australia vehicles (Territory had it)
Obviously its been redeveloped numerous times in the 16 years since
In D4 there was a 3.0 TDV6, then the SDV6, then the Euro 5 and Euro 6 versions
- al cope
and soon to be a straight 6 again (ingenium?)
- mordred1973
have they said when the Ingenium 6 Diesel (or indeed if) will be launched?
- Flat Earther
It’s gone very quiet on the straight 6 Ingenium diesel, despite the straight 6 petrol having been launched.
I claim no inside knowledge, but I wouldn’t be surprised if the idea is quietly dropped.
- Labbix
Fords contract to supply engines stops in September, with all the investments done in the Ingenium range, it would be strange not to go on with the 6 cylinder Ingenium diesel. Unless problems were found or a deal with for instance BMW was made, which I doubt for the 6 cylinders. And there are still rumors about it, but not too many indeed
- Equilibrium
The lack of a new 6 diesel is a little strange. The Defender would interest me with a V/I6, at a lower price than the X MHEV.
I guess MY21 changes will be known soon across the range, so the diesel 6 short term strategy will become clearer.
- mordred1973
theres news items in the USA that the Defender will have an inline 6 diesel, with 296PS compliant with California Ultra Low Emissions regulations. So I would assume a more powerful version will be offered in the D5 in Europe, where emissions regs are not as tight as California hence more power.
It could of course be a MHEV, with the battery taking the place of the spare wheel.....since the 6 cylinder petrol will be too thirsty for anyone to consider running.
