  • scotty
    2017 Discovery TDV6 SE Indus Silver
    roof rails
    need a set of roof rails , any recommendation would be great, seen a few but some say you need to buy finishers as well
    wasn't 100% sure if needed them or not
    cheers
    scotty
  • al cope
    Yes you need finishers as well. See my thread in the tips and tricks section from when I fitted mine..
    You can use your original finishers there are marks on the back where you need to cut them out but as Al says it quicker and easier to buy the ready cut finishers
  • scotty
    just a quick update,,
    got roof rails fitted, didn't buy new finishers, they came with templates, so i just cut holes where needed without removing anything.
    cheers
  • HPRMunster
    Hi Scotty,
    Did you fit the roof rails and cut the finishers yourself? Also, did you purchase the OEM rails?
  • scotty
    sorry for delay,, yes i cut the finishers myself and fitted them myself, not that hard to be honest
    the finishers at the front are aluminium and the back ones are plastic, the ones i got came with a template, all be it its not bang on but it gets you in the right area, there's plenty of cover on the rails anyway
    the roof rails were on in about an hour and a half, the cross bars on the other hand were a pig.
    link below to eBay for the ones i got
    cheers
    https://www.ebay.co.uk/itm/LAND-ROVER-DISC...2749.l2649
  • scotty
    They are quite as well
    if i could figure out how to put a picture up i would
  • HPRMunster
    Thanks for the response. I take it you cut the holes in the finishers while they were still on the car, rather than removing?
    What is the quality of the rails like? Are they the same design as the OEM rails?
  • scotty
    yes, cut them while still fitted to car,, used a dremel multi
    the rails are good, aluminium, same as oem as far as i know at a fraction of the cost, land rover quoted me £580 just for rails, supply only
    I'm just back from devon with 3 bikes on the roof no problems, from glasgow
    cheers
  • HPRMunster
    Blimey that’s some trip!
    Thanks for the info, Think I’ll probably go for them, I have a dremel too, good tip. Always good to get a first hand opinion Thumbs Up
