  • bammmy
    Are people still having problems with 20B or has the later version cured the gremlins. I’m holding fire downloading because I don’t want to inherit hassle👍
    Mark
    Dangerous thing for me to say, but after inital problem with Android Auto locking, the latest semi update seems to have fixed that and i have not seen any other issues
  • Chopsy
    I didn't have any issues with either of the 20B updates, but I suppose unless you try absolutely every function, you wouldn't know.
    Working great for me so far.
  • Slug
    2020 Discovery SDV6 HSE Silicon Silver
    Haven’t noticed any difference since my update a couple of days ago.
    Seems quite underwhelming really.
  • jungle42
    Hi there, from March to August I had the little download arrow symbol on my ictp (version 19c), I started the 20a update several times but it did never finish (i had to leave the car, sometimes you just arrive at your destination;) ) and after restarting there was no more update available.
    But today, finally, 20b has been installed and the arrow symbol is gone;)
    What I did realize by now was: if the arrow symbol is white, then it says "no update available" but when it's grey, than go ahead and you can get the update.
    No issues so far after a 150 km trip.
  • Trevorb1
    With 20A I had a number of instances where the audio module didn't fire up for the whole ignition cycle, no audio from media or parking sensors and volume control did nothing, so far, since updating to 20B, has been OK (fingers crossed)
    Is this the new one? Only checked as I read on here there was a new version. Have to admit, I don’t use any of the infortainment stuff, Appleplay, radio, phone, navigation, so it doesn’t matter if it works or not. Laughing
  • Trevorb1
    Yep, that's the latest software
    Thanks.👍
  • PaulP
    Spain
    Mine has been very hit and miss since the latest update at the beginning of August.
    The InControl system has failed to boot on two occasions. It never happened once before in the years since I bought it.
    4x4 info and suspension travel is working fine though after being "broken" for the last year, so that's one small improvement.
    Interesting, wheel direction works on mine not the shock absorber position just stays as a grey post and doesnt move.
    In old days of 4 tile software the shock absorbers showed brown and the down bit moved....
    I think the "shock absorbers" do work. The top and bottom white circles stay in place, the middle grey part moves up and down. I'll take some screen shots of mine later today.
    Sorry, took a bit longer.
    I live halfway down a hill, driveway to the left when going down. Grass area next to the driveway which is higher off the road so I get a bit of suspension flex.
    Left front tyre on that grass area:
    Put it in off road height. Both front tyres on the grass, left rear tyre flexed close to max I'd say:
    Both front tyres plus left rear on grass, now flexing front left close to max:
    Right of the car is down hill, there was one point where both "shocks". were orange:
    Back on the concrete driveway:
    Suspension back to normal ride height:
    Suspension down to access height:
    I'm on 20B, this display works although I don't think the animation is intuitive.
    will try on mine, maybe haven't taken wheel travel far enough for it to show brown....also on 20B
    Otherwise it can be yet another thing for the dealer to look at next week, when they're trying to sort the super thudding active rear diff.
