D5Dodge
Anderson socket
I’ve used this on my D3, Jag XF & Evoque so it was one of the first bits I stock on the D5
Jump starting is the main use with cables made up to suit (175amp) I must get round to fitting a socket on the cables for my compressor!
I’ve started loads of cars over the years with it & even a ribcraft
once. Once on your car you’ll think of loads of stuff you can use one for..
