  • D5Dodge
    2019 Discovery Sd4 (240) SE Farallon Black
    Anderson socket
    I’ve used this on my D3, Jag XF & Evoque so it was one of the first bits I stock on the D5
    Jump starting is the main use with cables made up to suit (175amp) I must get round to fitting a socket on the cables for my compressor!
    I’ve started loads of cars over the years with it & even a ribcraft Shocked once. Once on your car you’ll think of loads of stuff you can use one for..
