  • tomex
    Poland
    USB and SIM module
    Hey,
    I have 2017 HSE version and unfortunately I don't have sim module hence can't upgrade InControl to support car play. (as read only with this module you can upgrade to new versions which support car play for free)
    Has anyone tried adding this module by yourself? Does anyone know whether all the wiring is in place and it's just adding module e.g. like this: https://partslinkent.com/2018-land-rover-d...er-socket/
    Thank you!
    As I understand it, it may be possible. Have a read here.
  • tomex
    Poland
    Thanks! That was useful, I just got new panel together with wiring.
    Any hints on how to disassembly center console - most prob. required to connect plugs?
    No idea, but the iPhone docking station installation instructions might help.
    The instructions start with Workshop manual section 501-12, which can be found in this post. Section 501-12 starts at page 9920.
  • NickHoward
    Problems with my panel
    I have a 2017 HSE with the centre panel with 2 USB and a SIM slot, but...
    I don't seem to be able to get anything to work.
    The USBs both work in that they provide power to my iPhone, but I can't connect to ACP (I get a connect fail message)
    The SIM card won't read (its a 3 PAYG data SIM), despite numerous attempts
    Having downloaded the latest map and followed the instructions to install, nothing happens after plugging the memory stick in.
    Am I missing something, is there a subscription or switch I have to make?
    Car connects fine to WIFI btw and have downloaded 20B sw via that route.
    Getting a bit short of ideas
    Nick
