- Wolfpack
2nd row seats not returning to upright
Using the buttons in the back of the car, I can lower the 2nd row seat backs and return them. The single seat returns to the correct rest position, but the double seat returns fully then moves forward again a couple of inches. As a result the seat backs are not vertically aligned with the other seat.
I am able to edge the seat back a blip at a time with the button....but one blip too far and it resets to the 2” forward position. I’ve lived with it for a while as I rarely drop those seats but lately I’ve had a lot of seat lowering requirements and it’s become a pain.
I am assuming it’s a sensor position? Is it something that can be diy fixed or is it a trip to the dealer?
- B McP
It may be that the controls on the lower side of the set have been set to a new position (the side facing the door), With the seats raised, try to alter the seat back position with these controls to the position required. Once done, the system should remember this position and return the seat to that position after lowering and re-raising. The controls are similar to those on there driver's and front passenger's seats.
- Wolfpack
Thanks...that’s a good shout. I did have a passenger in there before Covid ....they may have twiddled.
Will have a look in daylight.
- Wolfpack
You,were correct.
The seat adjuster had been moved.
