  • andynoiseboy
    How the hell do mice get in the cabin??
    I recently found some mouse butt-nuggets on the passenger seat so I've been placing a trap in the car. I must stress, I'm not happy killing any animal but the potential for damage here outweighs my morals.
    So far, I have caught 3 field mice, and I suspect that's nt the end of it.
    My question is, how can they get in there when the car can wade through 3 feet of water without cabin leaks?
    Can i ask if you transported bales of straw or hay in the boot by any chance, and its possible the mice were already nesting in there already.
    My friends a farmer and advised me too always pick up straw,hay or chicken feed in the trailer as he got an infestation in his Vauxhall Frontera years ago which nibbled his wiring and set his car on fire.
    (I find it's far easier hosing the trailer out than all the mess left in the boot, especially stuff like coal, logs, sand, cement and chuckies etc. I usually get straw for putting around the strawberry plants).
    All that ever goes in the boot is the weekly shopping.
  • andynoiseboy
    That makes sense Roadrunner, but I haven't had anything like bales in there since, as you say, you're better off with the trailer for that.
    I haven't been using the car very often since china attacked the world and I did leave it in the field for a while. So I can see that mice could be interested but never thought that the cabin might be accessible.
    Mice are acrobatic little Censored , and they also chew through stuff pretty efficiently. Check your cabin air filter for a hole - my guess is they got in the fresh air intake for cabin air. That's all above the wading depth anyway. Had a coworker leave his beater truck in a field for 3 months, the first time he drove it, his A/c motor failed. Oh, well, just a beater, roll the windows down. Worked fine for a few days until the smell permeated the cabin from the dead mouse babies that had been killed when the motor seized on their squishy little bodies. You should also check the air box for a nest.
    If they're inside the car, they're already chewing on wiring harnesses. A different coworker leaves his car out at night...rabbits chewed through a wiring harness for his airbags, which was a $3500 repair.
  • Blackfly
    Chipmunks , although this one seemed to like German wiring!
  • andynoiseboy
    Thanks Diesel Ranger for your suggestions. I'll have a look to see if I can find anything around the air inlets, which I guess are at the upper bulkhead area.
    I didn't catch another overnight last night so I'm hoping that's it. We're very rural here and rodents are prevalent but this is the first such issue I've had. I put it down to the car standing for much longer than would be normal. Not sure what preventative measures I can employ to prevent this though.
    If you can't drive it regularly at least start it up daily and maybe run it around in a circle every couple days just to keep 'em guessing.
    Nothing much you can do about mice other than help them understand their prospective home is a noisy, dangerous place to perpetuate the species.
  • andynoiseboy
    I'll try think of reasons to make journeys. Just become more difficult today due to national lockdown!
    I'm wary of short journeys at the moment since I've recently had 2 DPF full incidents with no warning, despite both happening after long motorway journeys. Feeling a little fobbed-off by the dealer...
  • harrythespider
    You could try peppermint or clove oil around the intakes not too much that it distracts you but enough to deter the little blighters.
  • andynoiseboy
    I've read mixed reports on 'smells that repel'. Some say that mice very quickly get used to it.
    In this weather, I'm not sure how long it would be effective.
    I haven't trapped any more for 2 days now so maybe it's under control.
    My advice though is be vigilant if you're not using your car (any car) much right now. Keep a close eye out for little butt-nuggets in the wells and on the seats.
  • phillh
    I decided to check the air filter on my 2017 TDV6 today. The filter was spotless but the bottom of the box was littered with dead leaves, seeds and small nuts and the foam insert at the bottom had been chewed up so I suspect field mice have been in there at some time during the cars 9 year life.
    I will check again in a week or so Thumbs Up
    It's always a thing with us rural folks...checking under the bonnet, wheel arches and air filter for bird nests and mouse poo. The little bleeders haven't managed to SAS their way into the Bling Barge yet but my D4 was a prime target for them coming into spring. Neutral
  • phillh
    Thanks Mole, will monitor and may bodge a wire mesh in the airbox entrance if they are getting in here.
    Thanks for the tip re Tayna Batteries btw, I ordered one today.
    Will I get away with fitting it and not coding it? Its worked my RRS, BMW and E class cars in the past without coding.
    Always glad to help where I can, Phill. I've used Tayna down in Llandudno for a few years when it comes to ordering batteries online... from my lawn mower up to my Land Rovers and they're highly recommended. Thumbs Up
    As for recoding the BMS after a battery replacement, I know some folk don't believe it's that important but there's a lot of gubbins relying on the BMS for voltages, charging rates for the battery...etc, etc. If you don't recode the BMS, it'll still be using the charging rates from the old, tired battery you just replaced. Besides the possibility of chucking out weird electronic errors and DTC's, it'll reduce the life of the new battery over time.
    My honest advice, if you haven't got a diagnostic tool and intend to work on the D5 yourself, even doing basic maintenance...find a decent priced generic OBD2 diagnostic tool that covers most basic service and maintenance related functions on a modern Land Rover (as well as many other manufacturers).
    Seriously, you'll need one somewhere along the line even if it's just resetting the service interval after an oil and filter change or putting the parking brake in service mode to change the rear pads. I have an iCarsoft CRMax which I use for other cars of different makes in our family...but the listed functions for my D5 is impressive, even compared to the mighty IID tool.
    Recommended, apart from the CRMax which is an expensive outlay just for occasional use, is the iCarsoft LR V3.0, which covers most service and maintenance related functions on a D5. There are other generic OBD2 tools from Launch, Autel or Otofix that cover a D5...but all of those tend to be prohibitively expensive and few (if any) of them have free lifetime software updates like the iCarsoft range.
