    Fuel economy
    Right did a tank to tank fuel economy check in the D5 which has now done 1000 miles
    This was over 420 miles mainly motorway with cruise control on doing a steady 75 80 but with some A and B roads. The trip showed an average of 31.4 but actual figure was 30.2 which I was pleased with. The trip meter was fairly accurate and the car is not yet run in I also find cruise control is not very economic so I would think that 35 or more will be easily achievable when run in and not using cruise control.
  • rd450
    hows it comparing to your D4 on similar journeys
    Difficult to say as it isn't run in but thinking back to the same sort of mileage in the D4 and similar driving I recon this is easily better on fuel by 4 miles per gallon
  • Sacimiddx
    Reckon you're​ about right maybe even a little pessimistic
    The ffrr did easy 34 at 75 mph pushing 40 at 60mph
    Allowing for less drag on the D5 but a little more weight (steel subframes) the
    D5 should impress
    Gut feel is the 2.0 will not be significantly better
  • S2bear
    Just averaged 34.5mpg
    on a 99.7m round trip.
    Mix of urban, Motorway and rural roads.
    Stats for last leg of journey were: Distance 46.5 miles / duration 1:41 / avg speed 30mph / efficiency 37.5mpg
    Was doing around 75 on the motorway and average speed was low as I hit town traffic in rush hour but with stop/start on etc. Not too shabby I guess.
    3.0td6 with 1,600 miles on the clock on 22s if anyone cares.
  • max099
    Austria
    Sounds good. Is this a calculated value, or is it what the car tells?
  • S2bear
    It's what the car & the Journey's App says.
  • J77
    According to my ones eco data my best trip was 38mpg but the trip computer says 26, that's more like it.
  • APL
    Ireland
    In which case Land Rover need to pulp all the current D5 brochures and fix the typo's in the fuel economy section!
    Still don't get how they can have got it so fantastically wrong!
    [the brochure quotes up to 54mpg for the 2.0Td4 Ingenium engine on Aero wheels, extra-urban]
  • J77
    It ain't real world testing, this is the problem and it's perfectly legal until it's changed we won't see true accurate figures
  • fisherman
    I was looking at the XC90 T8 Hybrid which claims 135 mpg, Fuelly.com shows it to be 35 mpg. Only 100 mpg out from real world consumption.
    D5 is way better in just about every aspect so won't be looking Sweden's way when I'm ready to upgrade.
  • max099
    Austria
  • SiliconFed
    Days driving through France.
    Working on fuel used was actually 22.8.
    Fairly well loaded up using cruise control most of the way, as you can in France!
  • APL
    Ireland
    What engine?
    If that's a full tank of fuel that can only manage 360 miles to a tankful, then.........not so great, is it?!
    Even if it was fully loaded up. Strikes me all the new aerodynamics are not worth anything??
  • SiliconFed
    3.0l diesel. Was averaging some good speeds and not all flat so not bad. But am a little dissapointed having done same trip in 4.4 L405 and doing better mpg. Maybe will improve once run in. Will monitor on the way back.
