  • DiscOlly
    2019 Discovery Td6 HSE Lux Indus Silver
    Can you fit roof bars without roof rails
    Hi, sorry if this is covered elsewhere - I’ve search and drawn a blank.
    My D5 doesn’t have roof rails and I wanted to fit a pair of old Thule Aerobars, but can’t find a fitting kit that will allow attachment to the roof without rails. Has anyone managed to fit bars without rails? I don’t want the monster roof rack system (versatile?) as I have bike carriers and roof box that fits with the aerobars...just don’t seem to be able to fit them to the car Surprised(
    Olly
  • joness7
    2019 Discovery SDV6 SE Santorini Black
    No, you will need the roof rails.
    The fittings are different to the old D3/D4 in that the Thule foot clamps around the rail rather than a T track system.
    The rails are a fairly simple self fit job.
    2019 D5 SdV6 SE Anniversary black/black
  • DiscOlly
    Thanks Joness7,
    I was thinking that was going to be the answer Surprised(
    For such a capable car, I’m surprised by the 60kg limit on the roof rack - I was thinking this limit was because it’s balanced on the rails, so was hoping I’d misunderstood. Might need to look a lighter bikes moving fwd too then - doh!!! (Tow bar mounted bike carrier not an option when towing a caravan).
  • joness7
    Bikes on the roof are difficult. It was easier with the D3/D4 where you could lower the bottom part of the tailgate and get a helper to stand on it.
    There are some options for a rear bike rack AND still tow, www.pbr.co.uk for example. I have their tow ball mounted rack, and it works fine.
  • DiscOlly
    I was hoping that fitted on the tow-ball that’s there and then adds another, but I think this would fit on the tow bar (not ball)...maybe I should patent this idea quickly Surprised)
    I already have the electrically deployable tow ball, so I think adding this would be a very costly retrofit. I am wondering if I can make something to fit on the A-frame of the caravan - I think there’s head room on weight there...will need to check.
    Thanks for the thought - much appreciated.
  • Trevorb1
    You need to be careful mounting anything between car and caravan especially when maneuvering, UK built caravans tend to have comparatively short A frames in comparison with German and I think Adria also bear in mind, although the electrically deployable towbar on Disco is rated to 350Kg, the A frame on Alko chassis are only rated to 100kg although the hitch itself is likely to be stamped 150Kg,
  • DiscOlly
    Thank you Trevorb1 - I’ll look into the Alko hitch limit - from memory, it was more than my Honda could take, which was 100kg, so I always pushed it to 90-95kg. I’ve not towed with the Disco yet, but my intention was to increase the nose wheels weight some more...will have a dig through the manuals!!!! Thanks for the advice.
    First time joining this forum - I’m already glad I asked the initial question.
  • al cope
    Alko hitch limit is 100kg, and the electrically deployed towball has an odd shape to it, so even some of the clamp around bike racks don’t fit ( I have looked at this for our bikes whilst towing the ‘van.)
  • GEOBLRDISCO4_SOFAR
    Bike bags
    DiscOlly. i bought some padded bike bags, the ones designed for putting bikes on flights, tied down at the front of the caravan inside, gets round the problem
  • DiscOlly
    Thanks GEOBLRDISCO4_SOFAR, I’ve not seen these before - just had a look on Amazon and can see what you mean. I’ve set 2 cycle carriers up in the middle of the caravan before (fixed to a couple of bits of wood) but when they have been used on hols they get a bit dirty...and I’ve managed to wipe the gears on the sofa before when putting them in Surprised(
    These bags look like just the job!! Thanks for the tip.
