  • 2B
    Netherlands
    Manual not correct
    I am trying to check the level of AdBlue.
    The manual says its in the menu under 'vehicle information' (2017 build),
    but there is no such tag at all.. Who owns a 2017 SD4 and knows where to look ?
  • B McP
    I recall that when I had my 2017 HSE Lux it had the analogue instrumentation panel and it did have the Ad Blue level.
  • 2B
    Netherlands
    I checked all online manuals : they are the same in this respect for all model years,
    I guessed somebody deleted an older version and misfiled a newer model manual..
    It's an HSE so if any had a level indication, this should have..
    Or it's a result of one update that deleted this function if its hardwired differently.. Confused
  • nebc100
    My 2017 HSE Luxury doesn't give the actual level, just says if the level is OK or not. It is in the same menu as for the service interval.
  • 2B
    Netherlands
    That menu 'service'does not exist in my car..
    Its either 'drivers assistance' or 'vehicle info' ; both have no submenu with
    service interval or anything on AdBlue..
    The phone app has the info, in the 'status' section:
  • Seaby
    I think the SD4 and TD6 have different menus. On my SD4 I don't think I can find the oil level via the screen / menu. Dipstick only
  • 2B
    Netherlands
    Also the app is different. It only tells me service is required in 25k km..
    I found it in the menu but you can only have the ignition on, not the engine running.
    Under Vehicle Information, "Next Service"
  • 2B
    Netherlands
    OK. I'll try it out !
    No luck. Not only the app looks to have a different setup,
    it doesn't show more details when the car is running..
    Big Cry
    Sorry, I meant the in-car vehicle menu.
    This is what shows in mine. In the first 2 pictures, the ignition is on but engine not running.
    and selecting that shows:
    With the engine running, the "vehicle info" menu changes and the "Next service" menu item disappears and "show warnings" is greyed out:
    The good thing is your's shows no issues, in which case you'd have enough DEF for 2,500km at least (provided you're not towing heavy trailers a lot).
    Easy way is on the phone app, it shows you the adblue range there.
  • 2B
    Netherlands
    Not in the phone app I have.. ..most recent according to playstore.
    Check screenshot of my post on the 11th..
  • 2B
    Netherlands
    found it !!!!
    The problem is the poorly (bad) translation of the manual. Shocked
    They refer to menu's with names that don't exist ; the onboard translation differs from the manual,
    as the manual and the car menu have different titles
    On top of that; other menu names are nearer to the phrases in the manual... Rolling Eyes
    Where the manual says "Bestuurdershulp" (=driver assistance), the name of the relevant screen
    is "Boordinformatie" (=onboard information / vehicle info)..
    As there is another screen with the name "Bestuurdershulp", and one with "Vehicle settings",
    only the submenu "next service" took me to the correct screen... Confused
