  • al cope
    Possible braking issue
    My D5 seems to have developed an issue under braking. The symptoms are that for a given pressure on the brake pedal, the brakes feel like the are braking then easing off then grabbing again and so on until you come to a stop. It doesn’t happen every time I brake, and it doesn’t feel like brake shake as I had that on both one of my D3’s and really bad on a D4. Done nearly 27k miles and there still looks like a decent amount of front pad material left.
    I do have a new set of front pads sitting in the garage so tempted to throw them in, but I can’t say this feels like a pad or disc issue.
    Air in the brake fluid?
    Any thoughts?
  • Qwertyd5x
    Check your rear brakes. Mine were thru to the metal in 23k miles, no warnings, disks also f*****. Suddenly the fronts and ABS were having to work a lot harder. Front pads and disks still had plenty life left in them.
  • John C
    Is it definitely your brakes? I have a weird thing which feels just like that, but I am sure it's the engine braking... it's almost like you are downshifting through the gears as you come to a stop, but it's changing into too low a gear (you can actually see it happening on the rev counter). Never been aware of an autobox engine braking under normal driving before. I can't work out if it's a feature or a fault, but is maybe linked to some odd transmission whine I have.
  • al cope
    Now you mention it, maybe it is engine braking, I hadn’t noticed the Rev counter changing but will look next time it is happening.
  • al cope
    Your right, it is engine braking, noticed the Rev counter change on the downshifts. Wonder why it’s started doing this recently?
    More noticeable when coming to a stop downhill.
  • John C
    V interesting! Do you have any sort of transmission whine at low speed on overrun?
  • John C
    (Ps autobox flush and reset doesn’t solve it)
  • al cope
    None that’s noticeable
