  • John C
    Rear washer
    Should there be a non-return valve or something on the pump for the rear screen washer? Seems every time I run it for the first time you hear the fluid move through the pipe above the drivers seat and it takes a few goes before the fluid comes out the rear jets?
  • harrythespider
    Funny you should mention this, when I first got my D5 I can't remember a delay on the rear wash, but now I have the same as you. I wondered if there was a valve that has failed.
  • nebc100
    Mine comes out first time. Don't have to run it multiple times.
    My rear washer works fine, but you do hear the fluid travelling in the pipe above the driver.
  • DaveRitz
    2020 Discovery SDV6 HSE Fuji White
    I had the same problem with my 2017 D5. The non-return valve had failed and was replaced under warranty.
  • John C
    Thanks very much for the replies.
  • harrythespider
    But where exactly is the non return valve ?
  • B50int
    From the workshop manual:
    REAR WINDOW WASHER JET
    The rear window washer jet is fixed into the rear spoiler by plastic clips. The washer
    fluid feed hose from the front/rear washer pump is connected to the jet. The washer jet
    contains a non-return valve to prevent washer fluid draining back to the reservoir.
    Sound like its part of the washer jet itself.
    Jon
  • harrythespider
    Started to dis-assemble rear trunking/grommets for washer jet thinking perhaps LR078293 might be suitable, everything is incredibly tight and doesn't appear to have any spare tube so gave up. Will have a chat with local stealer as to how its replaced and with what.
  • sdouglas7
    2018 Discovery Td6 HSE Loire Blue
    I've had this problem, but now there is a leak eminating from the top of the A-pillar where the airbag cover meets the roof trim. Assuming there's a pipe clogged or somethin, not yet dismanteld any thing to have a look.
    There is also a non-return valve in the rear door for the rear camera wash jet. If either that one or the one for the rear window jet fails, air will get in and let the fluid drain back to the tank.
