  • CJM625
    Activity Key programming to my car
    Hi all,
    I've bought a new boxed activity key from ebay and I believe it has to be coded to the car, is anyone on here doing this kind of service please and if not any suggestions? I'm in Merseyside.
  • BBDisco5
    2022 Discovery SDV6 HSE Lux Carpathian Grey
    Do you not also need the receiver which goes inside the rear hatch?
  • CJM625
    I believe it's standard on the HSE Lux but I'm open to being educated
  • BBDisco5
    Mine is a 2020 HSE Lux but the rear receiver wasn't pre-fitted.
    I underdstood the activity key and receiver come as a matched pair and/or you need the bar code which is on each part/plastic box the activity key comes in.
    The receiver takes minutes to fit - takes longer to take the tailgate trim off.
    If you are stuck locally, there is an independant in Stockport who can do the programming.
  • CJM625
    Cool, thanks for your help and advice
  • FastLaneJB
    There’s no rear receiver on the facelift models. It’s just a normal key by that point as it’s the activity key v2. Don’t know if that’ll work with older cars but I mention it as I don’t see why in theory it couldn’t if it’s just a normal keyless entry kind of key by that point.
  • CJM625
    Mine's a 2018 MY HSE LUXURY
