  • adds58
    MY22 HSE Interior Ambient/Mood Lighting
    I'm sure I read somewhere that with the new model there was some sort of configurable ambient/mood lighting as standard with the HSE but I can't see anything in Pivi Pro. Is there something I'm missing or am I imagining it?
    Thanks,
    Adam
  • stereo247
    South Africa
    2019 Discovery TDV6 HSE Corris Grey
    Apparently there’s an option on one of the screen to the (swipe) right.
    Recall seeing that somewhere - my 2019 doesn’t have this
  • drwhopilot
    Re: MY22 HSE Interior Ambient/Mood Lighting
    adds58 wrote:
    Thanks,
    Adam
    Interesting point. I also have the HSE and have no idea how that works
  • Equilibrium
    In ICTP (the layout of which is largely similar to Pivi), there is a dedicated tile on the ‘swipe furthest right’ homescreen.
  • adds58
    I just had a look and can't see one or any options to add a tile for lighting.
    Maybe its just standard lighting in the cabin in the MY22 HSE?
  • drwhopilot
    I found it but no idea if it has changed anything due to bright sunlight!
    settings -> vehicle -> cabin lighting
    Then it displays an external image of the vehicle. Which I initially throught wasn't very interesting or helpfull!
    BUT you must touch the image, then a menu appears and you can change the colour and brightness. I don't think either is infinitely adjustable as in eg Mercedes
    I think I read you need the external lights on to perform the function
    Update: just tried it in the dark and it is working. Not very bright even at max, and not that well distributed (I'm comparing with a Mercedes) but it does work...
  • teaman
    My MY19 HSE Lux has that menu option, allows you to change the colour of the lights. I played around with it for 5mins then set it back to white and left it at that.
  • adds58
    Found it. Didn’t realise you could click on the link. Thought it was just a toggle on/off
