  • Keith
    MY21 - D300 RD SE - Leek
    So...
    I'm gutted.... after a few days of heavy rain, and driving through some large puddles (slowly I would add), the passenger footwell is soaked, as you push the carpet the water squelches put of it.
    Any one else had this issue?
    keith
  • B50int
    Sympathies.
    Sounds terribly like a recurrence of the windscreen sealing issues that many others on here have reported.
    I recall someone posting picture of their screen seal when the glass was replaced. There were gaps in the sealant. Try searching for windscreen leak.
    Hope you get it sorted and it dries out well.
    Volvo XC90 T8 Ultra
    If LR can’t get something so basic right, it doesn’t hold up much hope for the rest of the car!
    Re: MY21 - D300 RD SE - Leek
    Keith wrote:
    So...
    Check behind the sun visor for water in the mirror recess and wet roof trim above it.
    I have posted elsewhere on the site my recent experience with leaking windscreen.
    LR dealers arranged to have National windscreens come to my house to fix…..I wanted to talk to the technicians and see what they found. (Cutting out dealer comms)
    In my case the problem was the primer applied to the windscreen was lifting and as a result so was the sealant. The guys said it was a common fault originating during manufacturer and they have been doing “dozens and dozens of all ages”. There are other stories on the internet from around the world with slightly different underlying issues. Of course there’s a lot of heresay online……I saw the primer problem with my own eyes
    They successfully removed, stripped and replaced the primer before reseating/ sealing and replacing the same windscreen….. the leak has stopped.
    They did advise me beforehand that there was a chance the windscreen could break necessitating a replacement to be arranged…. which is why they normally recommend the car is tackled at the dealers.
    But they were very good and clearly experienced with D5 screens.
