  • Doggieman
    Sweden
    SOS Limited functionality
    Hi Doggieman Dog here!
    Just acquired a Discovery 5 and really enjoy it, but I encountered an annoying error message that pops up - SOS Limited functionality
    Probably something already brought up but trying in vain to find any information on how to find the telematics box with the battery inside.
    Seems that many have had the problem (in my case I guess it is the battery, everything else is working fine and it has never been replaced since car was new)
    Can someone give me an understanding:
    1, Where to find the telematics box - preferable a description so I can find it, not an overview pic!
    2. How to access the battery and replace it
    It is a Discovery 5 MY 2017
    Would be grateful!
    Thanks in advance!
    Doggieman Dog
  • Aldo
    I had the error pictured.
    I also had starting issues and it turned out to be a faulty telematics control unit.
    Hopefully not the same for you. But I believe the module is in the boot offside near the battery.
    I did lots of googling and at first thought it was some sort of bad wiring or faulty internal battery in the unit. It was neither.
  • Doggieman
    Sweden
    Thanks for reply Aldo,
    Your error message is a bit different than mine, Tee message I have is that the SOS service is limited.
    After a lot of googling it seems that is referring to a battery that is worn out (hopefully).
    Have you renewed your Incontrol subscriptions?
  • Doggieman
    Sweden
    Jimbg,
    Subscriptions renewed and SIM card active and functional,
    The subscriptions had expired but is renewed and working
    SIM datacard exchanged and working (downloaded upgrade so I know it is working in car)
    Thought of buying a new battery LR046049 for the TCU but need to find the TCU to be able to replace Very Happy
    For Range Rover Sport
  • Doggieman
    Sweden
    Thanks, will have a look in the trunk Smile
  • vkord
    Lower left C pillar
    If you pull left passenger door rubber seal you will be able to see purple cable and connector that are going to TCU module but not the TCU itself because it is black and it is dark in there, To access TCU you would need to strip upper and lower c pillar panels. Failure of those batteries after 4 years is not normal IMHO and should be covered by CPO warranty, but my dealer has opposite opinion.
    The tip of umbrella pointing to the approximate location of TCU.
  • Doggieman
    Sweden
    Thanks for all repsonses.
    After a visit to the repairshop everything went clear!
    It was NOT a faulty battery, it was discovered that the car has been through a severe collision and by that some electronic issues has not been repaired fully.
    After I realised that I have been able to cancel the deal and get a full refund since the dealer never conveyed that is has been crashed and got branded as "salvage" car.
    Thanks again for your sugggestions!
    Doggieman
  • Aldo
    Woah that is scary! I must admit it crossed my mind with mine when I had that similar error.
    Hopefully you’ve managed to replace with another Discovery 5?
  • Doggieman
    Sweden
    I got back my old car since they hadn't sold it yet.
    So for the moment I'm back in a Range Rover Sport of year 2013.
    Need to find another one but I'll wait for the right one this time Wink
