- Lucy2
Alarm goes off when locking
Any ideas on this folks, when I lock the car with the fob one press the alarm goes off 5 seconds later, if I double press fob there's two beeps then alarm goes off right away. Checking last alarm in dash
it says rear n/s door not locked, but it is locked. I locked the car manually with key everything locked fine but there's no alarm on.
Do the door lock catches have alarm sensors in them? Thanks in advance.
- Lucy2
Answer this one myself folks, just ordered a new lock mechanism fitted it myself, took around 3 hrs bit of a fiddle getting it out & back into place, didn't help being - 3 degree's fingers don't work as well. So it was the module inside the lock not sending message to alarm that door was locked. All working fine hope this helps someone else. 😉
- Craigp
Thanks for getting back with the fix. Much appreciated.
