  • docf
    Austria
    reversing camera often doesn't work
    Hello
    i have some issues with my reversing camera. Often the camera doesn't work. Also a error camera system faulty appears.
    I think it comes more often it rains or in the snow.
    Had anyone the same issues?
    Where can I start to search the fault.
    Thanks in advance
    Franz
    Software update I think 🤔
  • docf
    Austria
    No I found the fault.
    I disassembled the rear tailgate lip where the camera is mounted. And the I saw that there is everything wet.
    I saw that there is a sealing on the upper and the lower side of the Lip.
    But on the lower side the sealing is only about half the lip in the middle.
    So I think water can get into the Lip left and right the lip.
    I think this is not a great construction so I will search If I can find any sealing which will fit.
    Also i will seal the connector for the camera.
    Has anyone the same problems ?
  • Duckers
    Had a similar problem with the rear tailgate being wet inside, it was identified as the rear screen and camera washer hose had split ! Replaced under ext warranty Smile
    Regards
  • docf
    Austria
    Thanks for your answers!
    Today I checked the connections from the camera.
    I put some "Kontakt 60" a really good contact fluid on it.
    But sadly the camera doesn't work.
    I will order a new one and will test it again.
    Regards
  • Noel1234
    2017 Discovery TDV6 SE Aintree Green
    reversing camera not working
    Can anyone tell me how to take the camera out to check contacts and how easy it is to replace Thanks
  • Benjibenji59
    Hello I also have fault saying camera system fault, can I buy a camera on line and fit or does it need coding from Land Rover ?
    That’s if it is the camera at fault is there another things to try first ? Like a rest or something?
    Sorry I don’t know much about this at all
    Thanks in advance
  • andynoiseboy
    Resurrecting an old thread....
    I have an intermittent rear camera with the same symptoms as the OP - system fault after wet weather.
    Could anyone advise how to disassemble please.
    Often when I try, I end up breaking plastic clips and causing even more damage!
    Any pointers gratefully received.
