- CRV Man
battery
Hi all just found out battery on the way out, Is it possible to change the battery one self or is it a dealer job
- 747_JK
I have no DIY/technical skills whatsoever, but you can book The AA to come and do car batteries on your drive (and a few other providers)... just in case you don't fancy going to the dealer or Halfords!
- nebc100
Battery is no problem to change. The hardest part is opening the side panel on the right of the boot.
- Russell
The car has to be told that there is a new battery fitted.
You don't need to access the battery. You can charge it by connecting to the jump-start connectors under the bonnet.
- nebc100
To CHARGE it, there are charging terminals under the bonnet…. To CHANGE it, you have to take it out.
One day, I will learn to read......
- nebc100
- Disco
Battery
Jump leaded with my van the two prongs at the front took it for a 10 mile drive came back and put the ck charger on and it showing 12.7 volts ask AA Man to check it and he says it’s ok
My fault do not leave ignition on for ten mins while checking tires
- David426
I changed my battery. It wasn't too hard of a job. I did not have to tell the car anything.
I didn't have an extension long enough to reach the top nut holding the retainer bracket. I loosed the bottom nut and bent the retainer up and made the swap, no issues.
