  • conts355
    Boot storage
    Does anyone know if you get nets or similar to store things in side compartments?
  • BBDisco5
    2022 Discovery SDV6 HSE Lux Carpathian Grey
  • conts355
    Yes Thanks!
    Not cheap thro is it…
  • BBDisco5
    As my late mother would say - you could make it yourself out of black knicker elastic Laughing
  • B50int
    I had one in my last d5 and it’s a piece of proverbial.
    The netting isn’t attached to the metal frame. The frame is just threaded trough a seamed pocket around the edge. So, all that happens is the netting is pushed down the frame sides after a bit of driving around and anything stowed behind just rolls out anyway!
    Looks good in the picture but practical only in the showroom I would suggest from my experience.
    Jon
    Volvo XC90 T8 Ultra
  • WmDisco
    2018 Discovery TDV6 SE Silicon Silver
    It is expensive but works if you fill it pretty full. I have first aid kit, pump and Hi-Vis vests etc. Yes - it can slip down but I am sure this could be solved.
    Could also make your own I am sure.
    Previous Disco 5 didnt have one. 2023 Disco 5 does. Definitely a positive improvement for otherwise dead space.
    I haven’t looked at the dimensions of the recess but these sort of elasticated nets are frequently used in caravans/motorhome for stowing ‘stuff’, and cheap as chips.
    Might be worth looking in that direction.
    https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
  • Loz
    I have made my own in the past with some bungee cord. If you remove the panel, you can make some holes in the edges and thread the bungee cord back and forwards to make the webbing, you can also use some webbing tape if you need it to be more substantial.
