I had one in my last d5 and it’s a piece of proverbial.
The netting isn’t attached to the metal frame. The frame is just threaded trough a seamed pocket around the edge. So, all that happens is the netting is pushed down the frame sides after a bit of driving around and anything stowed behind just rolls out anyway!
Looks good in the picture but practical only in the showroom I would suggest from my experience.
Jon
MY23 (2022) D300 SE R-Dynamic Eiger Grey, Tow Pack, Matrix Headlights and a few other options
Gone: 2018 HSE 3.0 tdv6 Santorini black
It is expensive but works if you fill it pretty full. I have first aid kit, pump and Hi-Vis vests etc. Yes - it can slip down but I am sure this could be solved.
Could also make your own I am sure.
Previous Disco 5 didnt have one. 2023 Disco 5 does. Definitely a positive improvement for otherwise dead space.
I haven’t looked at the dimensions of the recess but these sort of elasticated nets are frequently used in caravans/motorhome for stowing ‘stuff’, and cheap as chips.
I have made my own in the past with some bungee cord. If you remove the panel, you can make some holes in the edges and thread the bungee cord back and forwards to make the webbing, you can also use some webbing tape if you need it to be more substantial.
