- Dixie Dean
A few questions re Air Suspension
What air suspension comes as standard on an R Dynamic HSE? Does it do both access and off road heights?
There is only one type of air suspension. It actually has 7 heights.
From lowest to highest...
1. Access Height
2. High speed driving height - lowers slightly from normal height when driving above 105mph (I think) to improve stability and reduce wind drag
3. Normal height
4. Off-road height 1 - 40mm above normal- automatically lowers to normal above 50mph
5. Off-road height 2 - 75mm above normal - automatically lowers to off-road height 1 above 30mph
6. Extended mode - automatically raises above off-road height when the vehicle detects that it has grounded on something.
7. Super extended - can be manually selected once the vehicle is already in extended height.
- Dixie Dean
Thanks JonM. Just doesn't get a mention at all in the vehicle blurb. I presumed it did (I have a D3 with Low and High gearing and air suspension, and all the terrain control gizmos) but with this vehicle I'm only going to get High gearing (no 2 ratio transfer box) and wondered if anything else gets deleted as a result. Do High only vehicles get any type of Terrain Response?
