  • Marsie
    Our 2017 first edition
    This is our new (to us) Discovery 5 first edition. Got it last Wednesday. Very happy with it up to now especially the fuel economy. Recognise a few names off the d3/4 forum which I have been a member off since 2010. Have owned dozens of landrovers but this is our first d5. Got a rattle to sort on the drivers door but other than that we are loving it
    Paul
    2017 3.0 First edition. Silicone silver with black pack
  • 747_JK
    Looks really super. Love the colour/wheel combo. I hope you enjoy it!
  • Marsie
    Thankyou, it's a big step up from the d4
    I used to call my D4 a D400 because every bill associated with it was £400+.
    I now call my D5 a D500.
    Enjoy your new car.
  • Marsie
    Fixed the door rattle today. Was only when shutting the door but sounded dreadful. Stripped the door card off and the plastic inner membrane. Found the rattle was the side impact bar had come "unstuck" from the outer skin and was resonating when slammed. Couple of small rubber wedges inserted to slightly open the gap and a squeeze of tigerseal along the length of the bar before removing the wedges. Now no more rattle when shutting the door Cool
  • Marsie
    I will soon require new tyres for the D5 and its currently on 285 40 22 pirelli scorpion verdes. I have been looking at something a bit more AT and have seen general grabber AT and yokohama Ats but these are 285 45 22. Has anyone fitted the slightly higher profile?
    the other alternative is to go 275 45 22 but would rather have the wider tyres to help stop my other half kerbing the alloys
    Just seems the 285 40 22 is very limited for choices
    I always use this site when considering new tires in a different size. https://tiresize.com/calculator/
    You'll find the outside diameter is what makes the most difference - stick with the known width, and play with the aspect ratio.
    I run 255/70-18 on Compomotive PD1881 wheels and that works out to an OD of 32.1". I believe 33" OD tires will rub especially at access height and/or at full lock.
  • Marsie
    Thanks. Would like to stick with 285 width as it offers a bit of protection to the rims but it depends if I could go up a profile to 45 without any issues. Time to get the tape measure out I guess
    According to the comparison site by going up to 45 profile I am going up 1.1 inches in diameter so providing I have more than 1/2" clearance I should be OK. But I also have to allow for a new tyre vs worn tyre so probably nearer 3/4-1" either side Confused
    At that point, best to check the specific brand and size for their actual outside diameter and sidewall width. Tire size standards are only guidelines, actually tires can vary.
  • Marsie
    Bit of a brake upgrade today. Fitted the 6 pot brembos that I had on my d4. Gave them a bit of a refurb first
  • Marsie
    Another job completed today. Replaced all 4 lower front arms. Although everything was still intact there was a lot of give in the large rubber bushes. I decided to bite the bullet and replace the lot. Now feels like a new car again 😎
  • JohnnieW
    Can the 6 pot brembos replace the smaller brakes on a 2017 3.0d? what parts do I need? Is it a straight swap, or what is the procedure? thanks
  • robpenrose
    I was going to ask the same?
    I’ve been looking at some 2017 Si6 D5s at it appears they changed in 2018 to the bigger brakes as standard.
    Did you notice much of a difference between the smaller and larger brakes?
    Currently a D4 owner looking for a D5.
    Nice brake upgrade, digging the red caliper paint too. Bow down
  • Beno2
    Welcome to the D5 crew I have been on here a short time having been on the D3 site for years Thumbs Up
