- 4x4newbie
Low engine coolant warning twice and then nothing.
Had the low engine coolant warning light yesterday twice, then nothing since, anything to be concerned about, how do we check thanks?
Open the bonnet and look at the coolant level when the engine is cold. Is it between the max and min marks? If not, top it up as necessary.
- 4x4newbie
ok looked and its low, where can we buy some from please for delivery, don't want to drive it. Which one from Halfords do we get?
- 4x4newbie
Should be fine.
Don't fill above the "maximum" mark on the tank. Then check frequently to make sure it's not going down quickly which would indicate a serious problem. Going down very slowly due to a little evaporation is quite normal.
