  • GC001
    Rear diff (non locking) confusion
    Is the rear diff capacity a measured amount or fill to a thin line starts to drain out?
    It’s a non locking diff, and drained out 800ml
    Fill to spill (as per the JLR instructions) meant I’ve put about 1.3 litres in.
    Have I don’t right, or should I have put 800ml back in and called it a day?
  • nebc100
    This might help. Taken from Workshop manual for D5
    https://1drv.ms/b/s!ArnTJXjEEbAUiNxh1SzYcp55pDZM8g?e=kQ0MBX
    As you can see... it is "fill till overflow".
  • GC001
    Thanks for the link, that’s the one I used
    If I filled it to the drain level it’s 1.3 litres
    I drained out 800ml
    Every oil guide illustrates a wet refill capacity of 8.2-8.5 litres, hence my confusion!
  • GC001
    Castrol and Liqi Moly sites
  • nebc100
    8.2L for the rear diff???!!!???
    I think you are confusing th engine oil quantity with the diff oil quantity.
    I have done all the services in my D5 according to the LR service manual.
    Engine oil is normally about 7L (tdv6)
    Transfer box a bit over 1L
    Front diff a bit less than 1L
    Rear diff(open) approx 1L
    These values are also on the Liquimoly site
    I don't know where you got the idea that the rear diff takes 7-8 litres!!
  • GC001
    It’s a typo!
    Meant to type 0.82-0.85l
