  • conts355
    Brake pad replacement
    Hi All
    Is replacing brake pads front & rear possible to do your self without any software required for
    electric brake etc?
  • Duckers
    Checkout the previous posts on putting the rear brakes into service mode, lots of useful comments
    Just type "service mode" into the search page
    I had trouble getting the car into service mode following the advice there until I didn't hold the accelerator pedal fully down but just short before the kickdown position.
    Hope this helps
    Duckers
  • Duckers
    Hi again
    from my earlier post regarding brake pads changes
    There appears to be a variety of types and sizes of brake pads to fit the various sizes of discs and manufacturer (Brembo, TRW etc.) I found it easier to measure the size of the brake disc (lots of various sizes, front and back can differ) and check on the Advanced Factors website (they have parts diagrams for the various sizes of brake discs with part numbers).
    My 2019 has 363 dia Brembo at the front and 350 dia TRW on the rear
    Hope this helps
    Regards
  • conts355
    Hope this helps
    Duckers
    Thanks for ur info, does the service mode work with you MY21 onwards with the button as a brake instead of lever/switch?
  • Duckers
    Not sure, mine is MY2019, but I can only suggest you try it, If it works fine if not plan B, not sure what that will be though, hopefully other members with MY21 onwards will advise
    Regards
  • conts355
    Still looking for info on the above for my my21 disco? If anyone knows anything now 🙏
