- Coffeecup
How to set Parking Sensors to always be on
Hi, I've just replaced my 2017 HSE with a 2019 HSE (lower mileage) and want the Parking Sensors to stay active all the time, rather than have to put the car into reverse first (or find and press the button on the screen).
I simply want the sensors to bleep at me if I get too close to something, like when trying to squeeze slowly through a gap between a wall and a parked car, without having to take my hands off the wheel to press a button.
I had this on my 2017 disco, and would like it on this one if someone could please tell me how to set it
Laurence
2005 TDV6 S - Tonga Green, 2008 TDV6 SE - Stornoway Grey, 2010 SDV6 XS - Galway Green
2017 D5 HSE LUX 3.0 SDV6 Grey 2019 D5 HSE 3.0 SD6 White
- nebc100
If I remember correctly, you have to have the sensors on, and then go to settings, and there is an option to automatically enable the sensors.
I will check later, but maybe someone else will beat me to it.
- Coffeecup
Thanks, I'll give that an explore
Laurence
- Mole HD
Strangely enough, I'm still trying to work out how to do that on my '17 HSE since I have to keep turning the front ones on from the centre screen...it's annoying
So...activate the sensors then go into settings I take it?
- nebc100
Yes… when the sensors are working and you have the screen that shows the distance to objects etc, you have a button there for settings… you click on that and you have options.
I will take a photo to show it, but my sensors aren’t working at the moment as one of them has failed so I cannot use any of them.
New sensors arrived, just got to install them!!
Oh… if only I had time!!
- Mole HD
Many thanks for that, I'll set them up later...I'm knee deep in cleaning a silage pit at the moment...not the most pleasant of environments
- nebc100
Ok… sorry for the delay in responding… I have had a very busy week!!
So… to enable the automatic activation of the parking sensors… (note… this works on a 2017 D5… don’t think it is the same in a PIVI PRO d5)
You put the car in drive (does not work if in park!!)
Activate the parking sensors manually using the parking sensor icon in the display.
A “window” will open in the display.
Now press the settings button (in that window!!)
You will now have the option to set “automatic 360° pdc” on or off
Hope this helps
Nick
- Coffeecup
Thanks I will give it a go in the morning, and come back.
- Mole HD
Hope this helps
Nick
Many thanks Nick, worked fine for me on my '17 HSE
- Beno2
Thankyou works perfectly
- Lynchyy
Hope this helps
Nick
Is this only for 360 view spec?
I think my sensors are not working correctly. I was going to go about checking them, but then realised ive had the car a week from the garage. Back it goes (i bet they ask me to go through the warranty).
- Mole HD
I don't think it's anything to do with the 360° cameras, outside of the reversing camera, most D5 models will have 3 front and 3 rear parking sensors I'd imagine.
The 360° camera option on some models only replaces the centre front parking sensor with a wide angle camera, adds another 2 cameras underneath the wing mirrors and uses the reversing camera for a wide angle rear view.
In any case, unlike the rear parking sensors which should always be active when you select reverse gear, to activate the front parking sensors, you have to press the little traffic cone icon on the bottom of the centre display (or by activating the park assist feature if fitted). The traffic cone icon is lit up if they're active.
I turned the front ones back off the always on setting...since they started bleating every time they sensed a blade of grass taller than 2" in front of the car.
