  • Madrilleno
    2022 Discovery Si6 HSE Santorini Black
    What is the part called that meets the parcel shelf?
    What is the part called that matches up with the boot area cover and is attached to the boot door? And, can you buy just the crappy rubber clips for each end?
  • Madrilleno
    ChatGPT found it. LR082309 & LR082310.
    I call it "the useless bit buried somewhere in the shed" Rolling with laughter
  • Madrilleno
    That’s the wrong part too. Should be LR154794
    The numbers above are the clips that the crappy rubber parts fir into.
  • ThatMartinChap
    did you manage to get the parts and fit them? It looks like the connecting rubbers have snapped on both sides of mine and I wanted to order the same.
    D5 D300 R-Dynamic HSE MY21
  • ThatMartinChap
    hah - just realised that the whole thing is removable ! Just took me 5 years Smile
    That's going in the garage and I might just try and superglue the clips if I decide to ever fit it again, If that failes then it looks like you can get just the rubbers on AliExpress
