- Madrilleno
What is the part called that meets the parcel shelf?
What is the part called that matches up with the boot area cover and is attached to the boot door? And, can you buy just the crappy rubber clips for each end?
- Madrilleno
ChatGPT found it. LR082309 & LR082310.
I call it "the useless bit buried somewhere in the shed"
- Madrilleno
That’s the wrong part too. Should be LR154794
The numbers above are the clips that the crappy rubber parts fir into.
