- Keith
SPEEDO ACCURACY
Hi All
Been experimenting with the CCF settings (using an IID tool G4) to try and I prove the accuracy.
the settings that are altered are as follows..
MultiCAN-838 Speedo Market
Market 0 (+3.5% +2km/h)
Market 1 (+2%)
You also have to have all these 3 setting to match
MultiCAN - 838 Speedo Market. - set to Market 1
MultiCAN - 577 SpdoCalPercentScale. - set to 1%
MultiCAN -575 SpdoCalkmhOffset. - set to 0kph offset
Improves the accuracy as measured against a GPS unit, but the true sped is one figure, there cruise control is +1mph and the speedo is showing +2 mph from the GPS unit.
Has anyone had better results, and what settings?
I should add I am running std 21" wheels with a 275x45 section tyre.
keith
