  • Slug
    2020 Discovery SDV6 HSE Silicon Silver
    DPF Failure - Anybody Experienced?
    I had an orange engine light come on a few weeks ago, called LR Assistance, and they came out and cleared the codes, didn't really find a fault apart from DPF codes although all working fine. Same amber light came on yesterday, so LR Assistance came out again, and this time they have said that 'they can the previous codes, and todays and they believe that the DPF unit has failed'.
    Approx replacement cost is £2700+vat+fitting he thought.
    Has anybody else had any experience of this??
    Car is 2019 with full FLRSH and extended warranty (55,000miles), so hopefully it will be covered, but the LR Assistance guy was on the fence with that - I'll find that out when I contact the garage tomorrow.
    Thanks in advance Bow down
    As much as the DPF system is a complete pain, it's unusual and even unlikely for one to 'fail'. There are no moving parts involved, it's just an exhaust section with a few internal baffles with holes in them...a cyclonic injector that scoots in the DEF (Adblue) at one end and a temperature probe at the other. A bit of an over simplification... but that's basically what it is.
    The common cause of a DPF system recording a fault or failure is for the injector to be completely clogged with crystalised urea (synthetic pig pee) from the DEF solution in combination with the main baffle plates being sooted up and full of ash which stops the DPF system working to the point where even a forced regen won't solve the issue. Hence the 'fail'.
    I'm surprised that LR Assistance didn't at least attempt a forced regen, it may have helped by temporarily solving the problem rather than just clearing the fault codes, telling you it's broken and leaving you to get on with it.
    Although it's extremely rare, I have seen the temp probe failing or being broken off...but that can be individually replaced for a fraction of the cost of replacing the entire DPF unit.
    Having the DPF system cleaned professionally or tackling the job on your own with a 5L bottle of Wynn's DPF cleaner will usually solve the problem. I'd suggest cleaning out the throttle body and check the operation of the butterfly valve at the same time should you go down the DIY route....a sooted up throttle body or a sticking butterfly valve can be a contributing factor (amongst others) with repeating DPF faults.
    The DPF system can be cleaned in situ without removing it, which is how small indies (and me at home) or mobile DPF cleaning services do it...but that requires a pressurised bottle fitted with a rubber tube to inject the cleaning fluid via the DEF inlet pipe on the unit...which is by far a lot easier than removing the entire DPF unit. Although not quite as effective as removing the DPF and soaking it in Wynn's for 10 hours...it works.
    One of the first bits of preventative maintenance I did on my '17 HSE after I bought it was to clean the DPF...since cleaning or servicing the DPF system isn't included as part of LR's normal servicing schedules, the chances are it had never been looked at since it was fitted in the factory.
    'Servicing' of the DPF isn't normally required since the DPF system 'self cleans' or regens as part of it's normal operation. The DPF unit does build up ash and soot on the baffles over time though so an occasional clean will help alleviate this.
    A lot of stop-start or short distance town driving doesn't help as the DPF has to get up to temperature to work properly... Once a month, blast it up the motorway or get the engine up to 3k RPM between gear changes to get that second turbo kicking in once it's up to temperature will help a bit. So...if your main driving is at low revs around the town...get it out of the garage, get the boy racer shades on, flick the gear selector into sport mode and thrash it every now and then Cool
    It's not a particulary difficult job removing the DPF unit except for requiring a bit of heat to unscrew the temp probe...the only necessity being after cleaning the DPF... either off the car or on it... you have to tell the car's ECU via an IID tool or similar ODB diagnostic tool that the DPF unit has been replaced. Just clearing the fault codes with a diagnostic tool after cleaning will do absolutely nothing except put the warning indicator on the dashboard off for a while.
    Chances are that many of the smaller Indy garages or local services that offer DPF cleaning may not have an IID tool or diagnostic software for Land Rovers. It's an issue to be aware of and should be enquired about at point of contact should you decide to try having the DPF cleaned. The 'on the car' cleaning process takes upwards of an hour roughly if done properly and costs vary...shouldn't be more than £200 typically....but I'm going back a while.
    In the unlikely case that you can have the DPF unit replaced under warranty...go for it by all means, but in the end...I'm quite sure that Land Rover will be perfectly happy to relieve you of 3 grand to replace your dirty DPF for a shiny new one Whistle
    A couple of links for specialist Land Rover DPF cleaning services:
    https://www.ukdpfcleaning.co.uk/services/land-rover-dpf-cleaning/
    https://dpfexperts.co.uk/mobile-dpf-cleani...-cleaning/
  • nebc100
    Actually, I had a DPF fail on my 2017 D5
    Fortunately it was covered under my extended warranty. The LR garage that replace it told me that the DPF had “cracked”.
    I thought that this was just a bit surprising that this happens 6 months after the same garage had replace part of the exhaust (also under warranty).
    Just recently, I had some work done at a garage that I trust (they USED to be a LR registered repair centre but have stopped working with JLR) and they told me that there was a series of DPFs that had a manufacturing fault and a lot of them did end up cracking and having to be replaced.
    I don’t know how many are involved though.
    Yup, the DPF unit is part of an exhaust system...and as such goes through extremes of heat and cold as does any other part of the same system. Having the seams fail or the unit crack... manufacturing fault...or again the extremes of heat and cold (and wet) on a galvanised metal exhaust part.
    Besides structural failure, there's no moving mechanical parts to 'fail' is what I meant, it's an exhaust box (like a silencer) with internal baffle plates, a DEF injector and a temperature probe is all...overly simplified description again of course.
  • nebc100
    I know… the issue on mine was that the actual honeycomb filter inside the DPF cracked in two pieces and so stopped working properly.
    Apparently this was the issue in a series of DPFs
  • Slug
    Update:
    DPF failed according to the dealer and needs to be replaced.
    Costing £3065 for them to do it.
    No covered by the LR extended warranty..
    I’ve asked if they can get a contribution from LR if I get it done.
    The best part is the replacement DPF is on back order with no eta.
    Fuming!! Censored
  • nebc100
    How old is you D5?
    I had the Dpf fail on my d5 and it WAS covered by my extended warranty.
  • Slug
    Oct 2019.
    Owned from new with FLRSH
  • nebc100
    Ah… that might be why… here you can only get up to 5 year warranty… not more. Maybe that is why mine was covered and they don’t want to cover your one.
    DPF is not covered by the UK Land Rover named warranty. In fact it’s specifically excluded mores the pity.
  • Slug
    Update: Good News!!
    I've had confirmation that JLR will cover the full £3000 cost of replacement DPF inc fitting, so fingers crossed it will be sorted in the next couple of weeks.
    Perhaps proving that it pays to have a full JLR service history as well as the extended warranty.
    Really pleased that they have come through with this on a vehicle that will be 6 years old in October.
    Thanks JLR.
  • Jonnydisco
    Cracked DPF - SDV6
    I’ve just had the dreaded call to say my DPF is cracked. 2019 SDV6 107k miles. Bought private so not a prayer on warranty and mind is blown that a replacement ‘exhaust part’ is £3k plus fitting.
    Also just shelled out for new throttle body and big service… is this just a baptism of fire into LR ownership or do I need to start selling my organs to fund this habit? Shocked
    I realised early on that the discovery 5 should have been labelled discovery 500….because every time it goes near a garage, the bill is at least £500.
    The only consolation I might offer is that it costs a lot more to change the discovery for another vehicle than repairing it. Without warranty the only sensible route is using an independent garage. Whilst genuine new parts are expensive, indies seem to be able to source cheaper suppliers…and with technician hourly rates more than half the dealer charge, it reduces the pain. Eg Diagnostic at dealer £190…at my indie £70.
  • Jonnydisco
    I went independent but DPF and associated components can only be sourced from JLR… so that’s £3k for a DPF and £700 for a couple of sensors that were lost in the process +fitting! Grateful for the couple of hundred quid labour I’ve saved but feel robbed all the same!
    Would love to hear of anyone else with failing DPF’s at the 100k miles/7 year mark…just to understand if I’ve been unlucky or if it’s a wider issue.
    I've heard of one or two cracked or failed DPF's on D5's, mentioned above by Slug and NebC but besides that, it doesn't seem like a common problem, not judging from what I've read at any rate. Like DPF's, EGR's or catalytic converters fitted to most modern diesel vehicles to comply with exhaust emissions regulation...they're a pain in the rear we have to live with. They do occasionally fail like everything else and they're unfortunately expensive to put right when they do. Neutral
