- Mod5
Help! Suspension Issue- B1DB7-93
I heard a pop sound while queuing to refuel my D5 a few days ago, the suspension stopped working and the ride has been very bumpy ever since.
I got a diagnosis with code B1DB7-93
What does this mean please, can anyone help interpret?
Best regards,
Mo
- Wolfpack
The pop sound I got meant the suspension compressor seal had failed. £600+ for a garage replacement unit. Cheaper if you diy …..or get an indie garage to simply drill out the rivets in the “sealed” unit and fix the inners.
- Mod5
Thanks Wolfpack, Much appreciated.
Any direction/ guideline on how to DIY please?
I just got a £800 quote for replacing with a used compressor and £1400 for a new one.
Regards,
Mo
- Wolfpack
I am assuming that’s JLR dealer quotes…….or maybe I am out of touch?
I got my local indie garage to do it for me a couple of years back, at the same time as a service, as fortuitously it went ‘pop’ 2days before its was due to go in! The actual cost was lost in the total bill but from memory it was only a couple of hours work and a few bits. Send a PM to
https://disco5.co.uk/forum/member-tomthumb.html on this forum he had it done recently.
I would give some of the independent LR garages or 4x4 specialist near you a call.
- TomThumb
@Mod5
If it’s the compressor pressure valve that’s at fault,
if your lucky you might hear air escaping from the rear of the boot floor on the o/s after selecting off road hight & closing the doors.
Otherwise the compressor will have to be removed, drill the casing rivets out to check the condition of the valve & compressor.
Parts were c£40 (all in £222) & took 90mins to do, well took the indi 90.
5mins to swap the pressure valve, but 85mins for diagnostics on fault codes / strip down / refit.
