    Disabling Auto Stop/Start using the GAP IID tool (Gen 4)
    A small CCF tweak with the IID tool to have the auto stop/start remembering what it was last set to instead of being enabled by default on every engine start...
    This relatively simple CCF edit doesn't permanently disable or effect the operation of the auto stop/start in any way, it only sets the function from being enabled by default on every engine start to actually remembering what it was last set to. If the last setting selected was disabled, it'll default to that when you start the engine.
    If you want to switch the auto stop/start on or off at any time while driving...just use the button as normal.
    Before starting this operation, please make sure your battery is good and fully charged, uploading new CCF values into the ECU's takes a couple of minutes...
    A disclaimer... Changing certain CCF values are generally something you don't want to be randomly messing with, you can brick your nice Land Rover should you try playing with certain functions or parameters. Stick to what you're confident with changing. Always save your cars default CCF values before making any changes so you can restore them if needed. The IID tool is a powerful bit of kit, so use it accordingly.
    That said and out of the way...Plug in your IID tool. Wink
    Start the engine and select the auto stop/start switch to off...
    With the engine running, fire up the IID tool app on your phone or tablet and go into Car config.
    Select all then wait for the complete CCF list to load then search for MultiCAN-566 MHLastUserMode in the search box (or do it the hard way and scroll down the huge list till you find it) and change the Last User Memory Mode option from disabled to Enabled.
    Upload the new setting and wait for the car to update the ECU's and relearn the operation (takes a couple of minutes or so). The IID tool will walk you through this stage. Once completed and the car has been power cycled, next time you use the auto stop/start button it'll work as per the CCF change.
    I've tested this on my 2017 3.0L TD6, it works Thumbs Up
  • Trantorman
    Thanks I had that on my list of things to do
    what else have you done on yours?
    Apart from sticking silly bling bits and after market mods on it, I've done the usual IID tool service related stuff like calibrating the suspension heights, checking the DPF pressures and soot levels in live data when I cleaned and flushed the DPF, resetting the HVAC and the service interval after oil and filter changes etc.
    Besides the basic service or maintenance functions and changing the auto stop/start CCF option, I've not really messed around with sampling the rest of the forbidden fruit hidden away in the CCF list with the IID tool... yet. Wink
    All the usual attractive tweaks like enabling adaptive cruise control and a few digital dash options only work on the 2018+ D5's so aren't of any use to me...There are some generic CCF tweaks like enabling dynamic and configurable dynamic modes.
    Saying that, I haven't tried enabling dynamic and dynamic-i modes on mine yet to see if it works...I'm not sure if enabling the dynamic mode will effect my capability plus pack for instance...Since they're both Terrain Response 2 modes, it may be a case of having one or t'other but not both, I've no idea. More research required. Enabling the Dynamic modes without the active suspension struts would only be a software setting anyway...a proper factory fitted Dynamic pack option also comes with the active struts fitted to the car.
    My Bling Barge is an early 2017 TD6 HSE with the analogue speedo and tacho. It had practically the full suite of available toys already factory enabled or fitted before I got it fortunately... but I'm still experimenting to see what else I can and can't do with the current GAP firmware.
    Amazing tool the GAP IID...and besides the essential service and maintenance related functions that are almost too numerous to list, it's well worth a poke around in the CCF's if you're the curious type and don't mind the risk of invalidating warranties or the like...it's surprising what hidden functions you can turn on or off...
    The simple 5 minute CCF edit to enable the auto stop/start memory function as an example would cost £100 at a LR specialist like LR-Chip, more at a dealership, although I doubt a LR dealership would do it even if you asked.
    If anyone else who uses an IID tool discovers any generic L462 TD6/SDV6 CCF tweaks and settings, please post them up, I'll do the same if anyone shows an interest Thumbs Up
    Thanks for posting. My normal starting procedure is a 2-button start: Stab start button, stab auto start-stop to OFF.
    I have a new GAP tool - a sticky post that has some commonly used items like resetting service intervals, calibrating suspension height, etc would be awesome. The GAP people seem a bit surly and don't really seem helpful to me.
    Yup, the CCF edit to enable the auto stop/start button memory is a good one. I was the same as you with the 2-button start up. Now, it automatically defaults to being off. It does take a few days to get used to after having automatically pressed that button for such a time...checking the button light etc but it soon becomes the new norm just knowing it's off. Wink
    The guided height calibration for the suspension is fairly straight forward, it only needs a tape measure...perhaps a bit of masking tape to mark the centre point on each wheel hub for accuracy. The IID tool walks you through each step of the entire process.
    I'm no technical expert and more of an enthusiastic dabbler with the IID tool, with the other commonly used functions I've tried and tested, I'll try to do quick 'walk-through' posts in tips and tricks when I can get around to it Thumbs Up
    Don't think I can add stickies to the forum though, I don't have the required admin permissions.
